Sketcher options 1
SofiaB
27
Hello everyone!
So I'm doing an analysis on a big truss and to draw the welds I'm using the sketch option to partition the faces. That was until this warning appeared:
Warning: The limit for coplanar entities has been exceeded; therefore,
no entities will be automatically projected onto this sketch.
Use the sketch project tools to manually project edges onto this sketch.
After that, I went to the sketch option to try and increase the max coplanar entities to project(for example to the double) but it didn't let me. I will leave images to better express my problem.
Thank you so much for all the help, very much needed!
Try doing what the message says. Remove the Auto option at the sheet size and set it to 1e4 or lower.
The problem is that when I input a number lower than 1e4 for example, 600, that message appears.
Do you enter that number in the max coplanar option or in the sheet size option? Read my previous message carefully again.
