Windback
New member
- Apr 15, 2012
- 8
Hello everyone,
I have designed a steel part for machining and while drafting it, I fully defined all the functional surfaces as precise as needed. Then moved into other features but there are some features that I don't want them to fully dimension and restrict with tolerances because these features would be ok either way. The reason is that I don't want to deal with non-conforming parts at the end...
On the other side, ASME Y14.5 PARA 1.4b states "Dimensioning and tolerancing shall be complete so there is full understanding of the characteristics of each feature.". I got confused here, what should I do should I follow the standard or should I stick into engineering intent? What is the general practice for these situations. Any comment, advise and/or idea will be appreciated.
Thanks in advance.
Thanks in advance.
