YungPlantEng
Chemical
- Jan 19, 2022
- 94
I’m a construction manager and in order to get access to a tank farm containment for a new containment install I was informed they’d need all the conduit out of the way. Some of this is just batch wise systems that can be turned off no problem but there are several conduits supplying continuously operating lines and the only way to move forward on the project would be to have the electrical contractor relocate the lines as live (240/480). I’ve heard of live lines being worked on with utility power lines but I would assume it’s not common practice and I would be better served to seek alternatives. Will obviously raise this issue with the appropriate personnel but just want to make sure I have the correct idea
