ReverenceEng
- Feb 18, 2016
- 81
I am looking to learn how to calculate the rafter tie tension (for designing splices/etc.) in a wood frame roof with the inclusion of purlins/strongbacks.
I am working with an existing roof that has a wall-wall span of 45'6", so rafter span of 22'9". The roof is 3:12 pitch with 2x6 RR and 2x6 CJ. The RR are at 24" O.C. and the CJ are at 16" O.C., so our rafter ties are only every 48" O.C. There are purlins that dump back into the rafter ties above a drop beam. SEE SKETCH ATTACHED.
Owner wants to raise that beam, but getting it above the rafter ties would be hard due to all the "stuff" in the way. He wants to see if we can cut the rafter ties, install the beam bottom flush, and then (re) strap the rafter ties using a strap or tension device.
Problem is, ignoring the purlins when performing statics yields an unrealistically high tension force in the ties due to the very long rafter span and the low pitch.
I could make use "judgment", but perhaps there are some "best practice" for doing this or tips???
Any guidance?
Any guidance?
