user11596
- Oct 28, 2022
- 5
ACI 9.9.1.1
Deep beams are members that are loaded on one face and supported on the opposite face such that strut-like compression elements can develop between the loads and supports AND that satisfy (a) or (b):
(a) Clear span does not exceed four times the overall member depth h
(b) Concentrated loads exist within a distance 2h from the face of the support
First condition states some sort of loading setup which i need help in interpreting. Basically do a beam with a clear span < 4 times beam depth but is only loaded uniformly count as a deep beam and fall under the provision above?
