hacksaw
- Dec 7, 2002
- 2,586
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
"The pipeline was never in use, just prepared for technical operation, and therefore filled with gas," he said.
Now measurements from the Swedish national seismic network show that two clear explosions were measured next to the gas lines during Monday.
One of them had a magnitude of 2.3, similar to a perceptible earthquake, and was registered at measuring stations throughout the country.
- You can clearly see how the waves bounce from the bottom to the surface.
There is no doubt that it was a blast or explosion. We even had a station in Kalix that picked this up, says Björn Lund, who is a lecturer in seismology and director of the Swedish national seismic network, which measures Swedish earthquakes and explosions.
Same area
The first explosion was recorded at 02:03 on the night of Monday and the second at 19:04 on Monday evening.
The warnings about the gas leaks came from the Maritime Administration at 13.52 and 20.41 on Monday, respectively, after ships detected bubbles on the surface.
SVT has obtained the coordinates of the measured explosions and they are in the same area where the gas leaks were recorded.
- It is very close to the coordinates registered by the Swedish Maritime Administration.
As for the most powerful explosion, it is a distance of six kilometers, says Björn Lund, who believes that their measurements usually have a margin of error of two to three kilometers.
