EngDM
- Aug 10, 2021
- 706
Hey all,
There is a portion of clause 16.5.6.3 for top chords that is a bit unclear to me. There is a sentence that reads "For top chords with panel lengths not exceeding 610mm, Mf resulting from any uniformly distributed loading may be neglected". However clause 16.5.6.1 b) states that the top chord has to be designed for moment when a concentrated load is applied between panel points. I guess my question is, when you are analyzing a roof truss that was originally designed under the assumption that moment can be neglected for a new RTU or other point load, do you only consider the Mf resulting from the point load and ignore the UDL as clause 16.5.6.3 suggests? If the joist was originally spec'd to 95%-99% as is typical for joist manufacturers while neglecting moment, then any load I apply instantly fails the OWSJ since now I have to consider moment, even if the moment changes by <1%. I'm having a hard time justifying the need for the amount of reinforcing this analysis requires; I'm adding a 400lb unit located 3" from a panel point so it induces next to no moment.
