NX1969 - Flatten and Forming
Kenja824
Automotive
Nov 5, 2014
950
Using the Flattening and Forming tool, there is a section called "Transformation Objects". Any objects selected will move with the flat pattern.
If points that are selected have an "ID" attribute, the new points will have that same attribute. The attribute carries over.
However, when I give a line this same attribute, it does not carry over. The new curve is a spline and has no attributes.
Is there a Customer Default option or something that will fix this? Is there any way to get the attributes to transfer like it does with a point?
Ken
My brain is like a sponge. A sopping wet sponge. When I use it, I seem to lose more than I soak in.
