Burunduk
- May 2, 2019
- 2,516
Here is a figure from ASME Y14.5-2018:
And here is the definition of a pattern:
So, if no INDIVIDUALLY was stated near the second segment of the positional tolerance for the small holes, does the 6X near the detail name define a pattern of 6X4=24 holes? Or would your interpretation be that every 4X holes is a separate pattern anyway, and the 6X near the detail name only indicates how many such groups are on the part?
To ask it differently, does the 6X INDIVIDUALLY note near the second segment of position break up a 24 holes pattern to 6 separate patterns (that are also controlled with ref. individual D@MMB secondary references) or does it only mean that the anyway separate 6 patterms of 4 holes are controlled with ref. to individual D@MMB secondary references?
Y14.5-2018 said:pattern:two or more features to which a position or profile geometric tolerance is applied and that are grouped by one of the following methods: nX, n COAXIAL HOLES, ALL
AROUND, ALL OVER, between A and B (A ↔ B), from A to B (A → B), n SURFACES, simultaneous requirements,
or INDICATED, where n in these examples represents a number.
