NX 12 MOI (moment of inertia) section inertia tool.
Blase_McK
Industrial
Aug 26, 2019
12
So I need to do a section of inertia on a part that has a threaded hole that runs thru the entire part.
when using the section inertia tool it has the option for solid or hollow. when you choose hollow it asks for a "hollow thickness"
what thickness is it wanting exactly? the OD of the thru-hole or the thickness between the OD of the thru-hole and the OD of the part?
Blase
 https://files.engineering.com/getfile.aspx?folder=29f59f39-d73d-431b-a238-5357f362db27&file=section_inertia.JPG
Thanks! Don't post on here much so I wanst sure where to post it.
Blase
