NX 12 - Drawing view update Customer Default?
BDDrafter
Aerospace
May 15, 2008
3
Is there a customer default for delay drawing view update in NX 12?
I know where it used to be in NX 9, and I can manually turn it on thru the menu in each drawing, but I need it to be set so I don't have to turn it off each time.
yes, there is a reason I need this setting, as we have numerous people working on things at the same time.
Thanks.
Branden Loock
NX 12
You will find that option when you customize the drafting standard:
Customer defaults -> Drafting -> general/setup -> standard -> customize standard
Then, in the customize standard dialog:
View -> workflow -> delay view update
Note that this is a part setting, changing the customer default setting won't affect existing drawings. If you have one or more drawing templates that you use, you will need to open these individually and change the setting in the drafting preferences and save the file. Any new drawings made after this change will reflect your new preference.
www.nxjournaling.com
Got it, thank you... I had to change to site settings because of our Custom Customer default settings also.
Thank you for your help! We're good now!
