Model Corrosion due to humidity of autoclave
sineleviosa
Student
Nov 16, 2020
1
Hello
I am needing to model austenitic 316 Stainless Steel and the effects an autoclave might have on it.
I have an idea how I would model if temperature and pressure would have an effect on the material plotting young's modulus vs temp( from room 20C to 120C this should show that 316 SS would not be effected by the autoclave sterilization process. my issue with this part is I'm not sure how to go about changing the parameters so i can actually plot create a plot of my own.
I also need to create a model of the effects of corrosion on 316 SS due to the humidity from the autoclave. Which I would be able to relate that back to how it would react in the body.
For this one I'm not sure where to start. But I am assume that this has already been modeled before, could someone point me in the right direction?
