mrmyagi
Petroleum
- Feb 2, 2014
- 13
Suppose I have a 1'' schedule 80 pipe with a corrosion allowance (CA) of 0.126'', factoring in a 12.5% mill tolerance and using A106GrB, which leaves me with a remaining thickness of 0.0224''. While this thickness is acceptable from a pressure standpoint, I am concerned about the structural integrity of the pipe. Is there a recommended minimum thickness for piping? For instance, should one avoid using pipes with a thickness less than 0.02''?
