dik
- Apr 13, 2001
- 26,049
I often encounter jib cranes with a circular post welded to a larger circular base plate. This connection is reinforced with numerous 'gussets' in a radial pattern. I would think that using a thicker base plate and eliminating the gussets would be less costly. This would include grinding the edge to reduce any tripping hazard. Is there a reason for using the gussets? Just to increase the stiffness of the connection?
Just curious...
Just curious...
