ImKass
- Jun 16, 2021
- 3
Good afternoon everyone,
I'm encountering 2 issues on EPANET 2.2 i'm stuck on. I'm sure it is both dumb ones, but my brain doesn't seem to figure out what they are, that's why i'm looking for your help ^^
FIRST ISSUE:
I've got a water system covering about 10 villages. I made 4 copies of it in order to differentiate the parameters i'm measuring in order to not forget one :
The CVM model works fine, but all the others are stopping right in the beginning (like 1h in), saying my "system is ill-conditioned at node J3483" and then all my reservoirs close
I'm sure my error might be dumb, but i need some strangers eye to have a look into it !
SECOND ISSUE
my second issue is on another model, that takes too long to run compared to other copies of it.
The same way as the first issue, iv'e got copies of the same model, but calculating different parameters.
The issue is, while 3 models run in an instant the last one, named "Modele_ChatelaudrunPlouagatPlelo_Temps de séjour" takes forever to run ^^
The .zip i uploaded contains both issues, with the exemples that doesn't have issues, and all configuration files (calibration, pattern, curves, etc...)
The First issue concerns the CCLP folder and the second one concerns the Chatelaudren-Plouagat-Plélo floder
i'm sure my issues are from dumb mistakes, but i can't figure them out ^^
I hope my explanations are clear, as it isn't my mother tongue ^^
I thank you very much in advance,
Imkass
FIRST ISSUE:
- CVM Gas measurement
Named : Modele_CCLP_CVM- Free Chlore
Named : Modele_CCLP_Chlore libre- Hydraulic diagnostic (for min/max pressure, max velocity and max headloss)
Named Modele_CCLP_Diagnostic hydraulique- Age (the time that the water spend inside the pipes before reaching its destination)
Named : Modele_CCLP_Temps de séjourThe CVM model works fine, but all the others are stopping right in the beginning (like 1h in), saying my "system is ill-conditioned at node J3483" and then all my reservoirs close
SECOND ISSUE
Imkass
