Wuest
Geotechnical
- Mar 22, 2019
- 2
I am building a system to test hydraulic conductivity in situ. A big component of this system is a water line that runs from the surface to some depth below the surface. The line will go from a water tank, to a pump, to a flow gauge, then to below the ground. My question is, would there be a way to determine the head added by the pump at any point in time (with constant flow and gravity head measurement) without fitting two pressure gauges on either side of it? I thought about using the pump performance curve to relate the rpm of the pump and the measured flow to the head given by the chart, however I believe that chart was developed assuming the water is being pumped from zero head to some head above that. In this case, the water would already be flowing even if the pump was off, so another question would be, does a performance curve show the amount of head a pump adds at that flow or does it show the amount of head added by the pump assuming the pump is the only factor causing the flow?
I would really like to get away with not purchasing two pressure gauges if I do not need to.
Any help or references you could point me towards would be greatly appreciated.
