eric1037
Geotechnical
- Jul 12, 2004
- 376
OK. I have heard this from contractors time and time again. They claim that by totally saturating soil, then letting it drain, it will "compact" the soil.
In all of my years of experience I have never seen this as an effective technique. I can understand that it is possible for fines to migrate between the soil particles and settle at lower elevations, but it seems like this would have very limited effect and only on "dirty" sand overlying "clean" sand or gravel.
I have read about this technique being effective for collapsible soils that have a structure that is weakly cemented by a water-soluble chemical or small amount of clay.
Also, I would imagine that you would need a very large head of water to achieve this affect. And by that point it may be more the weight of water inducing the consolidation than the water itself.
I have reviewed the paper at the following link and it seems to indicate that even where there is improvement, it is spotty at best and the improvement level wasn't enough to achieve specified compaction requirements.
I am an open-minded engineer and I always like to consider cost-effective alternatives. So, what do you think?
