How to select from currently opened CATParts and CATProducts?
Kattmandu
Automotive
Oct 31, 2022
7
Programming is not my expertise. With that said, I'm looking to implement a CATScript that asks the user to select from a list of currently opened CATParts and CATProducts listed under the "Window" pull down menu in CatiaV5. What would code look like to get the "window" items into a selectable list and save that filename into a variable?
Code:
Dim windows1 As Windows
Set windows1 = CATIA.Windows
Dim numberOfWindows As Integer
numberOfWindows = Windows1.Count
Sub FillArray()
 Dim array(numberOfWindows)
 Dim intI As Integer
 For intI = 1 to numberOfWindows
 array(intI) = CATIA.Windows.Item(intI)
 Next
End Sub
if it is a GUI, then you need to do it in VBA.
regards,
LWolf
