YungPlantEng
Chemical
- Jan 19, 2022
- 94
Trying to understand approximations for corrosion mechanisms impacting a quench tower nozzle that supplies water to so2 to cool it down.
I don’t want to get into details but from common texts I can’t really understand if a specific corrosion type is known to more impact the spray nozzle.
The metallurgist who studied the sample assumed sulfidation based on the sulfate samples existing, but my understanding is salts are a primary component of most sulfidation mechanisms, and no salts/carbon was found in the sample study or are expected to exist in our process.
I’m not really sure if I can make an assumption of “wetted surface” and say high temperature oxidation / sulfidation mechanisms aren’t relevant/aqueous mechanisms dominate the reaction.
And if we can make that assumption could we potentially move to a metal/coating more focused for its erosion protection / aqueous acid protection characteristics without needing to consider the system as high temperature?
Currently use c276 for this process and component lifetime improvement would be very beneficial. There is very little literature specific to this process and a lot of idiosyncrasies that I won’t cover here so apologize for the question if it’s elementary - don’t come from a corrosion background.
Thanks for any help! I can supply more info as needed but obviously IP purposes can make that difficult
