EngDM
- Aug 10, 2021
- 706
Hey all,
I have a table provided in a geotechnical report that I would like to use in a spring support model for a driven H-pile to get a rough idea on how it would perform. I am having some difficulty determining exactly how to calculate my spring constant per meter strip of height. Here is the table:
As you can see the table does not have any units in it for what D should be.
What I have done, say in the 4-9m region, is take 6.7/0.360m = 18.61MPa/m ----- I'm not sure if the units on this product are correct, but the table header appears to indicate that each cell would have those units.
If I then multiply by my 1m strip, I get 18.61MPa, but the spring constant I need is in N/mm, not mm^2 as is present in MPa.
Where do I cancel out the other mm?
