Help identifying this seal Please
Reddog_2
1
Hi, I'm hoping someone can help me identify the manufacturer or the type of this mechanical seal in the attached pictures . I will try to explain it as best i can. it is out of an old clayton waterbrake absorber. the stationary part of the seal is a cartridge with the spring loaded contact ring. its pressed stainless housing seals on the outside diameter. on the seal i found the numbers 91-275 931-001 but cant find anything on these numbers
the rotating part id turned stainless that appears to have carbon film on the sealing face, it has an oring in 1 groove and a backup seal in the other groove on the outside diameter that sits in a counterbore on the impeller. clayton shut down there dyno section so told me to jog on.
Any help would be awesome
If you can't identify the seal from the parts, it's sometimes easier to find a replacement that fits the seal cavity. If you can get measurements of the seat bore, shaft diameter, and installed height this should lead you to a replacement seal.
