Mccoy
Geotechnical
- Nov 9, 2000
- 907
I recently found that, from the result of a slope stability analysis on a situation of building on large-diameter foundation piles, the pile group appeared to contribute significantly to the strenght of the soil volume inside of it. that is, after inputting the pile group in the analysis, some failure surfaces disappeared or the FS's increased.
I'm a little cautious over these results, since the distance between piles axes is an average o 5 meters in both directions and it des not work as a proper retention pilesheet. Piles lenght is 12 meters, diameter 1 meter, high shear strenght.
Have you come across similar situations?
