Fonts per Y14.2 2014 standards
ieshadover
8
I would like to confirm that Arial Narrow meets the standard y14.2-2014? My understanding of rev 2014 we now don't have a min size on fonts (only a mim recommended .12) in title block it just needs to meet the one stroke, spacing between letters and be legible?
ieshadover,
I do not have a copy of that standard?
What are you trying to accomplish? Your font must be readable by the end user. I would make the following assumptions...
[ol]
[li]E[ ]sized drawings (44[×]34") solve all sorts of problems on drafting boards. They don't solve problems in 3D[ ]CAD.[/li]
[li]The printers in modern offices can manage A[ ]size and B[ ]size. There is no need to create title blocks larger than this. Even if you have a big plotter, it is unlikely your vendors have them. Your fonts should be optimized for these smaller sheets of paper.[/li]
[li]I am 66 years old. I can read 0.08" (2mm) fonts on drawings printed 1:1[ ]scale. I find them fairly readable on a B[ ]sized sheets printed at A[ ]size. I can easily read them on a 1080p monitor (1920[×]1080).[/li]
[li]0.1" (2.5mm) fonts on a B[ ]sized sheet are easily read on an A[ ]sized print, and on a cheap laptop with a 1368[×]768 screen. How do your vendors and other people you communicate with, plan to go paperless?[/li]
[li]The traditional 1/8" (3mm) lettering is readable on traditional, large drawings if they are on your desk or workbench.[/li]
[li]D[ ]size and E[ ]sized drawings do not fit on desks and workbenches. Usually, you hang them on walls, and read them from a distance. 5/32" (4mm) lettering is readable under these circumstances.[/li]
[li]5/32" (4mm) lettering is readable when a D[ ]sized drawing is printed B[ ]size. On E[ ]sized drawings, less so.[/li]
[li]If have a 24" plotter, you can print your B[ ]sized sheets doubled sized. Your fonts will be an easily read 4 or 5mm.[/li]
[/ol]
Good drafting is like good writing. You are trying to communicate. Anything you do to obfuscate communication will succeed gloriously.
JHG
The latest is ASME Y14.2-2014, restamped for 2020. I think there is no '2012 version.
It's sad. It was mostly about making drawings clearly drawn enough to survive microfiche reproduction, but time and technology have moved on. It used to have a bunch of unnecessary concessions to CAD software; at least I had a CAD admin stick to settings that, two decades before, saved 10 seconds on making a pen plot but made the drawing significantly less legible by setting the line widths too small. He justified it 'cause 14.2 said making garbage was allowed for CAD.
I have too many floaters so anything that helps by not being a small dot is an aid. It sucks. When I was a kid I could read microfiche without a magnifier.
Sorry I got it right in the subject but miss typed in post I am referring to 2014.
