Henrique Orlandini
- Dec 11, 2017
- 19
Hello.
I work with drive-pump trains that usually have API 614 lube oil systems (LOS) installed. Those LOS always have an oil return pipeline that works only with gravity, and this return line have quite a few temperature gauges + thermowells to check how hot the oil is leaving each equipment bearing. One question that I receive a lot is that, since the return line is not pressurized, how can I be sure that the fluid film thickness of the oil in the piping is in touch with the thermowell tip?
I use a standard 3 mm gap from the thermowell tip to the bottom of the pipe, the good old and dangerous "we always did like that, never heard a complaint before", but I want to be able to actually calc this thickness to have another argument for this question.
According to API 614 6th edition, annex I, item I.3, I can use the Darcy-Weisbach method to calculate this, but I have a doubt in which they call "pipe length". I know it sounds silly, but my oil return line doesn't have just one "source" of oil, it has several branches that connect to the header, thus the oil flow throughout the oil pipe varies with the length.
I'm sorry if this is way too specific, but it would be of great help if someone could shed a light on how to properly use this method (or some other method) to calculate the fluid film thickness of a gravity return line.
I'm attaching some snippets of the standard, in case it could be of any help.
