DoubleStud
- Jul 6, 2022
- 501
Lets say you have 6:12 shed roof. In the middle this roof you have a fireplace. How do you typically frame this? The fireplace will have thin set stone veneer, but the chimney above will be about 7 ft tall and will have heavy stone veneer. The chimney framing and fireplace framing will be the same size (stacked). The ceiling at this point is about 16 ft tall.
