oldestguy
Geotechnical
- Jun 6, 2006
- 5,183
As some of you know,I am 78, been at this game for a long time and doing a little still. I am trying to advise a small engineering-testing firm about STABL. I have used the DOS versions quite a lot, but have not used the Windows version. With the DOS versions I found the main problem using the program was properly setting up the "in" file. The error messages were not very good at helping to figure out what was wrong. As you might know, missing a 0 in front of a decimal point and other small required details sure made it a job to get any production out of it.
I see at least two firms are selling a Windows version, as is Purdue U.
Can anyone comment on ease of use, mainly on getting the proper parameters, coordinates, etc. in properly so the program will run? Do you set the whole input file up and some silly requirement later stops it? Or, does it advise as you input data that something is wrong right then?
How about form of output? I would doubt that the client needs those neat looking colored cross sections and bar graphs, but let's hear some critiques for and against?
Or is there a better one out there, better than STABL?
