Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
There is no Fire Load Case given in ASME BPVC Code. Usually, after a fire event, you/your company has to initiate a FFS. Essentially, it will be assessment of mechanical properties of components subject to heat exposure and re-rating/replacement if required.Hello guys,
I have a FIRE condition, and I should extract reactions in the support at W+P1+T_fire, but I'm wondering if it's necessary to analyse a sustained case corresponding to Tfire, knowing that I don't have nonlinear restraints
Many thanks
