ETABS Pier Compressive Stress Block Output
EngineerRam
52
Hi All,
Does anyone know how to extract compressive stress block lengths in ETABS wall piers for each design load combination? I am only able to view this info if I am exciting a boundary element requirement, but I would like to see these values for all load combinations.
My guess is ETABS will only show that info for the controlling design load combination - I'd poke around the table output but I'd guess you've done so already
Thanks Luceid. I did check the tables, but I am unable to find anything even for the controlling combination.
Yeah - I typically output the pier forces and use SPColumn or S-Concrete to draw the rebar/design the wall. A lot more user friendly than ETABS design output
