Error message in "Design Table" Excel sheet empty
Bogdan1985
72
Hi, it's me again.
I designed parameters and relationships. Everything is fine. I clicked "Design Table"
and checked "Create a design table with current parameter values"
But the button in the tree is missing. I tried to open the sheet from the location
and a new error message shows up in the window:
"The design table contains no data or its file wasn't found (you can use Edit Properties to change the source file}"
See attached image.
 https://files.engineering.com/getfile.aspx?folder=cc4dc9c8-d185-4763-b9ee-3cb6251f03b8&file=error-messsage.JPG
When you clicked "Create a design table with current parameter values" have you selected the parameters you want to transport to Excell?
After that there should be a prompt to save the Excell file, was it saved?
