EPANET
Help us help you... describe the problem you're encountering, and what steps you've taken so far to resolve the issue.
Dan - Owner
SABAOD...
I downloaded your model and found the problem in just a few seconds (at least the most obvious problem, if more than one exists). I am deliberately being cryptic because you should be able to find the same problem I found in short order, in spite of the fact that this is your first time using EPANET. HINT: check your data.
--Winston S. Churchill
