doingwhat
- Sep 10, 2013
- 21
Provide a calculation showing that the 5’-4” long branch line and drop, including the elevation gain from the
cooler ceiling to the existing branch line at .445 X 100 = 45.5gpm, is less than the staring pressure for the roof
level sprinklers at .5 X 11’-6” X 8’ = 46gpm. If the friction loss exceeds the elevation gain, provide a hydraulic
calculation for the cooler.
I figured out i should use the hazen williams formula for the arm over
(4.52 x (45.5)^1.85 )/ ((120)^1.85 x (1.049)^4.87 ) = 0.57 psi
so which formula i should use for the elevation gain?
