E-Plan Help
Ethan_Capps
1
Good Morning,
I am new to using the E-Plan software and at the moment E-Plans official forum isn't accepting new users for whatever reason.
Problem Overview:
In the E-Plan "Project Check" Function I have seen someone utilize a warning pop up display when trying to place a part into a "Restricted Placing Area" but I'm assuming it is specific to a custom display. I say this because at the moment my only options are "Prevent Errors" which just completely stops the placement of parts in the area (As the function is meant to be used) or the option is to use the other functions which just add a note to the "Message Management" tab.
What I'm Trying To Do:
Place a warning display that just informs a possible designer that they are placing a part into a restricted zone what gives them the option to still place the part if they deem it necessary but to still persuade them to explore other placement options and all and all to just be an informational display.
Thank You in Advance,
