Direct frequency response analysis
cocodrillo1
6
Dear Users,
I have to do a response analysis of a certain construction (NX Siemens, Nastran solver 108, Direct frequency response analysis)
How do you define such excitation:
Excitation: 9.81 m/s² ≈1 g
Frequency Range: 10…..500 Hz
Sine-Sweep: 0.5 octave / min
Thank You, Regards, Peter
Hi!
Discretize the frequency range logarithmically and you can create a forcing frequencies modelling object. After that you can define the amplitude for each of the defined frequencies as a constaint (enforced displacement)
Be sure that when you are postprocessing the results you don't exceed the sweep rate.
David
