DIN 5480 Root and Tip diameter tolerances
davidh729
51
I am working on a mating part to a customers product. They are using a male DIN 5480 spline that we have to interface to. What I have to reference is a competitor's drawing that calls out the hub spline as an N50x0.8x30x60xH9. We purchased the current (2006) version of parts 1 and 2 that seem to have all of the information for the nominal dimensions and the tooth form tolerances, but the standard only has any mention of tolerances on the tip and root diameters in their example table that has comprehensive data of the form I am used to seeing for gears. From the reference drawing I have and other threads I've looked through it seems that a full table is not usually provided when the 5480 short hand call out is used. How do the tip and root diameter LMC limits get determined if they are not directly called out. Am I missing something in the text of the standard?
Thanks in advance for the help.
David
Dave Hyman
Mechanical Engineer
N50x0.8x30x60xH9
Internal.
From DIN 5480-2:2006 Table 7 df2 and Adf2
df2=50+0,27
From DIN 5480-2:2006 Table 7 da2 and DIN 5480-1:2006 Table 5
da2=48,40H11 (+0,16)
Thanks Spigor. This makes sense now. The word recommended in 5480-1 Table 5 apparently didn't register and I was confused by the term deviation over tolerance.
Dave Hyman
Mechanical Engineer
You are welcome.
It all makes perfect sense in German, but apparently some of it has been lost in the German to English translation.
