raar
- Aug 17, 2010
- 14
This is my first experience with a Wye-Gnd to Wye-Gnd transformer with a internal grounded delta tertiary winding (no external terminals available for connection). I am trying to model this transformer for short circuit, load flow, downstream arc flash and it seems most modeling software require Zps, Zpt, Zst for positive and zero sequence along with the related X/R's. The test report clearly provides the T-model impedance's for the zero sequence circuit and so I am able to calculate the zero sequence Zps, Zpt, and Zst and X/R for each. The report also provides the positive sequence Zps and X/R, but I am not sure how to determine the positive sequence Zpt and Zst and X/R from the test data.
The report references IEEE C57.12.90-2015, which I have a copy of, but in section 9.3.3.2 for Three-winding transformers the test report does not clearly define Z12, Z23, Z31, nor Z1, Z2, Z3, therefore I am not exactly sure how to get started with determining the other impedance's. Could someone please provide some general direction or a clue on how to proceed with the determining the positive sequence Zpt, Zst, and related X/R's?
