Mohanlal0488
- Jun 26, 2020
- 103
Greetings Structural Gods
In all structural books I have looked at (mechanical and structural) it seems that the welds are always taken as a unit thickness (1mm), and this is used to develop the required mechanical properties.
I have been messing around with a program I developed, taking the element as a rectangular bar and calculating the associated stresses due to loading. There after I also do the same with the weld, however a unit thickness is not chosen, the actual weld thickness is used.
I have presented the results below... I would like to know some thoughts on the stresses presented? The stresses from the element to the weld do not flow numerically this is however due to the stresses on the weld and element been calculated separately
