cpanzner
- Mar 28, 2018
- 1
When installing pvc coated MC in a deck should you tape the ends with the red heads inserted in the MC connector. The box, wire and connector will be surrounded by concrete. When they pour the concrete the wires get moved around. I found the wire gets moved all over the place. The red heads gets knocked out. Is it alright to tape the ends?
