David Deck Guy
- Aug 18, 2023
- 36
I need a little bit of a sanity check on this. I'm installing a new pergola on an existing masonry. If I run this thing as a moment connection, the loads always blow up my anchors. I would like this to be a pin. My first thought was to bolt the HSS to two angles, which would then be epoxy anchored to the masonry parapet. Unfortunately, as they tend to do, the architect has already vetoed this for "aesthetic" reasons. Two options come to mind:
1. I am overthinking this, and its fine to model this as a pin.
2. Cope the flanges and web until the moment capacity of the coped section is less than the moment capacity of masonry connection. This gets complicated when factoring in combined loading, where the shear can fail the connection if it also included a reduced moment.
Any advice on this would be greatly appreciated, as I suspect its going to be a detail I use quite often moving forward.
