Consideration of Nozzle loads (from PIPING) in Flange Rating
gitsunil
7
This has reference to Code Case 2901 & ASME Interpretation VIII-1-16-85 (attached for ready ref) regard to checking of flange rating for external piping loads.
ASME Interpretation VIII-1-16-85, says calculation shall be performed to validate the flange rating (when there are external piping loads in addition to internal pressure).
Please suggest the guidelines/design methodology/procedure for flange rating check (under external piping loads)?
Best regards,
Sunil Agrawal
Best regards,
Sunil Agrawal
Tecnimont Private Limited
 https://files.engineering.com/getfile.aspx?folder=88a441b4-63d3-49f9-b564-86e0d76d7d45&file=Interpretation_VIII-1-16-85.pdf
Follow the Code Case. I don't understand the confusion.
Also, please note that Code Case 2901 is incorporated in the 2019 Edition under UG-44(b).
