confusing drawing. Why is the distance between the cutouts not dimensioned?
rollingcloud
Aerospace
Aug 9, 2022
174
[Reposting this thread as I had to remove my original post due to the inability to remove sensitive material.]
The size of the cutouts (bigger holes) is stated, but I have looked everywhere on the drawing and could not find the distance nor its tolerance. One of the drawing notes states, "GD&T TOLERANCE APPLIES TO NOMINAL HOLE LOCATION AS DEFINED IN DIGITAL DATASET." Does that mean that precise hole locations may be defined in a separate digital model or dataset not included in this drawing? Or is the drawing the digital dataset?
What is the function of the grid lines that do not seem to provide dimension nor location? Also, the true position of the fastener holes is strange. There is only one basic dimension, which is to the datum target C1. I still need to know the basic dimensions to datum A, B, and C in order to use that composite feature control frame.
Can I apply the .02 TP of the fastener holes to the bigger cutouts? Since they all share the same part, it would make sense for them to have the same positional tolerance.
The drawing does say that they have a photo contact master available for shop use, and undimensioned feature tolerance is +/- .03'', but PCM is more for inspection, right? For manufacturing purposes, we still need to know the distance between the holes and their exact locations.
See drawing here:
As I said in the reply to the original post, I understand what they meant to say, but the note is badly formulated.
As 3DDave also said, "GD&T" should have been GEOMETRIC TOL. if they really feel they must have it that way. My opinion is that they should have skipped altogether. They could have simply stated that unspecified basic dims shall be queried from the model or something similar.
But, it is not the confusing part. The confusing thing is "DIGITAL DATASET" when the intended meaning is the CAD model. A CAD model is sometimes referred to as a "digital data file" but not as a "data set". A data set is the complete product definition package and in this case, it also includes the 2D drawing.
Photo contact masters are usually used for photosensitive panels to do the marking.
They are supposed to send the digital dataset (model or DXF or PDF) with this drawing - that file is supposed to be identified in the drawing notes, which are not shown to us.
