gte447f
- Dec 1, 2008
- 802
I am looking at a concrete crib retaining wall that is loosing backfill through the face of the wall during heavy rain events. There is an obvious surface water drainage problem that is contributing to the loss of backfill through the face of the wall, in that their is a tennis court upslope from the top of the wall that is discharging a lot of runoff toward the wall. There are several area drains that are supposed to collect the runoff from the tennis court, but until recently those drains were completely clogged. The area drains have recently been cleaned out, but I am skeptical that it will significantly reduce the amount of runoff getting to the top of the crib wall. I am going to recommend that a swale be constructed parallel to the top of the wall to intercept runoff and direct it around the wall.
In addition to the drainage problem described above, the cribs appear to be backfilled with local site soils with a high clay/silt content. In my opinion, this is not an ideal backfill material for a crib wall, because it is susceptible to erosion/washout, which is exactly what is happening. There is a geotextile fabric located behind the front stretchers of the wall that is intended to retain the backfill soils, but the geotextile is degraded and failing over large areas of the wall, so it no longer retains the backfill.
Questions: If the surface water drainage problem can be solved and controlled, will that be enough to prevent further loss of backfill? If not, is it even possible to replace the geotextile fabric facing without excavating all of the backfill, or is there another option for retaining the backfill, like maybe shotcreting the face of the wall, or establishing a vegetative covering on the face of the wall?
