MRM
Geotechnical
- Jun 13, 2002
- 345
Please offer your opinion about the following. Correct, disagree, or make fun of me as required…
My current understanding and opinion are that "cohesion" should not necessarily be used for design purposes and it should not really even be recommended in a geotech report, if the actual strength parameters are to be used.
Some of my reasons for this are as follows; first, "cohesion" as it is plotted on a chart is sometimes an artifact of the curved Mohrs envelope, and second, cohesion for soils is not as reliable or dependable as it is for real rock. That is it may change with time. Cohesion is not easily defined, universally. Hmmm, perhaps we’ll hear more on that…
Therefore, effective stress parameters for a stiff clay (for example) should include a friction angle only. But very importantly, that friction angle should be unique to the stress range in question. The same holds true with a soft, NC clay-an effective stress friction angle should be reported if effective stress conditions are desired.
I’m not saying that you won’t arrive at the “right” answer in a bearing capacity calculation if a phi/c parameter duo is used. What I am saying is that I don’t believe the phi/c duo is as fundamentally correct as many would think.
What do you think?
What do you think?
