CATIA VBA Collapse Specification tree
NaWin55
98
Hello all
i want create a macro to collapse specification tree completely, i tried with following code
CATIA.StartCommand "Collapse All"
i used this method after checking one of the thread from here
but it is not working for some parts with big specification tree it will collapse tree features but not geosets will get
collapsed
is there any other way to do this which works for everything
hmmm maybe with something like this:
Activate tree manipulation, select top node, then combine multiple sendkey DOWN until you reach the bottom (or END) ... (you can check if the selection change) then use again sendkey LEFT to collapse and UP to go up the tree until you reach the top.
Eric N.
@itsmyjob
thanks for the replay
but how to activate tree manipulation and select top node
i have not worked much on tree manipulation and SpecsAndGeomWindow these kind of things
can you give some hints how to activate tree manipulation and selecting top node
thank you
catia.activewindow.layout = catWindowSpecsOnly
As this will hide the geometry, it does activate the spec tree.
Please check coe.org 2018 COE University presentation about the subject.
link
Eric N.
