Trestala
- Feb 15, 2015
- 180
I have an existing vessel that needs to change out the catalyst with a heavier catalyst and doing verification if the existing bed support (grid with mesh sitting on top of a support ring and beams) would be able to sustain the new loading. However, existing beam is a tapered H-beam where the ends are smaller than the middle part. Typical beam deflection formula can't be applied since it doesn't have uniform cross section along its length. Does anyone have any idea on how to check deflection on this beam?
