jball1
- Nov 4, 2014
- 78
I created a contact interaction in CAE. Now I can't seem to edit it. Specifically, I can't edit the initial clearance, which I have set to "Uniform value across slave surface: 0". I want to remove this initial clearance. However, it is not an editable field now, for some reason. I am trying to edit it in the initial Step, in which it is created. I am probably missing something obvious here. Any help would be appreciated!
