Calculating welds - Second moment of area
psoutzis
Student
Apr 19, 2025
1
Hi everyone,
I’m not sure if this is the right place to post this, but I’m hoping someone can point me in the right direction.
I need to calculate the second moment of area for a weld configuration. I have a hollow tube welded onto a flat plate (picture attached). The setup includes two intermittent welds, each 30mm long and positioned equally spaced around the circumference at an angle.
I came across the "sector of a hollow circle" formula in Roark's handbook, which seems helpful for calculating the second moment of area about the x-axis for a single weld. However, in my case, the welds aren’t aligned along the x-axis — they’re positioned at an angle.
Tube OD: 420mm
Fillet weld 6mm
Has anyone tackled a similar problem or know how to approach calculating the second moment of area for welds placed like this?
Thanks in advance for any guidance!
The second moment of area, as the word iteself says, is area x distance squared.
Pls post this kind of questions in the students forum
