Slickstir
- Mar 28, 2007
- 5
I've been asked to add a 6" steel drain pipe to a water tank that is open to atmosphere. The drain pipe will come straight out of the tank after a gate valve for approximately 15ft and then discharge to a ditch (no elevation change before discharge).
What is the calculation to estimate the flow out of the drain pipe when the tank level is only 1.5 feet above the pipe? They were hoping a minimum flow of 500GPM but I was wondering if they would need a larger pipe for that amount of flow at the end of the drain.
