Bottom Repair of Water Fixed Roof Tank
Inchtain
Petroleum
Feb 21, 2021
151
I would like to know if it is allowed/recommended to leave the weld build-up of limited pits of the Tank Bottoms or they shall be ground smooth? Which is better? and Is Visual and Dye Penetrant Examinations are enough for their inspection?
Usually, grind smooth for coating, not flush. Test with vacuum box or equivalent. If it's an API-650 tank, refer to API-653 for requirements.
My interpretation of API 653 is ,
-There are some limitations if the weld repair is within the critical zone,
-The weld repairs shall be ground flush with the surrounding plate material and be examined with visual inspection and PT/VB.
