ASME Section VIII Div1 Weld Seam Width
oguzzz
15
What is the weld seam width tolerance for as welded longitudinal and circumferential joints according to ASME SecVIII Div1.
Generally the Code does not address such tolerances. It will be a factor of joint design/thickness.
