RattlinBog
- May 27, 2022
- 186
I've read the other threads on eng-tips about this but could use some clarity on a couple things. Attached is an example I put together quickly--it's not a real structure.
1. When using Fig. 29.4-3 in ASCE 7-16, why does a larger ε=(solid area/gross area) ratio lead to a smaller Cf (and therefore smaller design force, F)? For example: ε=0.15 --> Cf=3.2 but ε=0.5 --> Cf=2.05. A larger ε means there's more solid area facing the wind. For some reason, I was thinking more solid area would lead to a larger wind force...
2. After you calculate the design wind force, F, how do you typically distribute that to the structure? Do you just take F and divide it and apply it equally at each panel point?
I'm probably missing something simple. Thanks
